Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
We set all of the in-game details to High and forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game. We tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4xAA, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA and 2xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction to Very High quality, we'll be pushing even the bleeding edge hardware on test to the limit.
Nvidia GeForce GTX 280 1GB SLI
Nvidia GeForce GTX 295 1,792MB
Nvidia GeForce GTX 260-216 896MB SLI
ATI Radeon HD 4870 1GB CrossFire
ATI Radeon HD 4870 X2 2GB
Zotac GeForce GTX 285 1GB AMP!
Nvidia GeForce GTX 285 1GB
HIS ATI Radeon HD 4870 1GB IceQ4+ Turbo
ATI Radeon HD 4870 512MB
Frames Per Second
20
30
40
50
60
70
80
90
Frames Per Second
20
30
40
50
60
70
80
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
There's less of a performance gap between the Radeon HD 4870 1GB and the GeForce GTX 260-216 in
Crysis' DirectX 9.0 mode and the factory overclocked HIS 4870 1GB IceQ4+ Turbo will deliver a reasonable gameplay experience at 1,680 x 1,050 4xAA 16xAF and 1,920 x 1,200 0xAA 16xAF. In both scenarios, the GTX 260-216 offers a smoother frame rate - equating to ten percent at 1,680 x 1,050 4xAA, but less than five percent at 1,920 x 1,200 0xAA.
Posted by Mongoose132 - Mon Jan 19 2009 16:16
"how well each graphics card handles explosions and congested ."
Congested what?
Posted by Xir - Mon Jan 19 2009 16:58
Certainly the GTX285 changed it.
Hmmm, I was hoping to go the ATI way but without crossfire (and yes that counts X2's)
But there is quite a gap forming.
Maybe I can hope for a surprise for the next CeBIT...
Posted by OtakuHawk - Mon Jan 19 2009 17:18
Posted by mrb_no1 - Mon Jan 19 2009 17:55
i think the final scoring for the card was fair, it does nothing to add to the 4870 imo, if i was buying, i'd get the stock and by a third party cooler with preferably a 120mm fan and then oc it with ease, as i wont have to contend with noise!
peace
fatman
